Excon11
Banned
Just picked up a set of escalade gauges. I want to do this mod so im gonna try and figure out a way to do it.
Where did you get them?
I should be able to put any window up/down without the key in the ignition. If I have access to the inside of the vehicle, what would it hurt to be able do that?
Large Draw?! c'mon. I could put all 5 windows open/close 50 times before the battery took a hit. I'd get bored before the battery gave out.
I can use the power lift gate, which uses 10x more power than a window with the key or without it being in the ignition. or the head lights even! you can't tell me windows draw more power than head lights...
the sunroof issue is a design or programming flaw. not being able to move the windows without a key in the ignition is just lame.
However most modern cars let you move the windows until a door is opened after the key is pulled.
My sunroof continues to close all the way when I pull my key out. There have been many times when I hit the auto-close button after I park in my driveway and then I pull the key out to exit the vehicle and it's never stopped nor reversed itself.
I picked it up from www.gmpartsdirect.com
