Esky taillights
bourgeois
start by removing 4 plastic pieces they are held by clips (remove gently) the top plastic is held by 1 screw
Begin removing the top piece held by 3 screws and clips on the side. The light is held by only 2 screws and 3 clips also (be gentle with the clips)
After everything is removed then just repeat the steps just take your time and everything will be ok. Quick tip if you get the lights I bought you will need to remove the factory harness.
The lights come with a harness and plugs right in. The plug you will be plugging into is at the bottom of the rear bumper.
Sent from my SAMSUNG-SM-N910A using Tapatalk
thank you
jmitchell
Did you test the lights before you put everything back together to see how hot the resistor gets? Where did you end up mounting the resistor? Any make/model info on those resistors or do they look custom done?
Anxious to see some pictures of the lights installed with lights on, blinkers, etc. Thanks!
I started this thread a while back with other good info on removing the tail lights for others...http://www.tahoeyukonforum.com/forum/showthread.php?t=62055
luigasca
luigasca
Yes I tested before putting everything back. Theses lights don't need resistors they are aftermarket not oem caddillac. It was just one plug that plugged into the factory harness no messing with any electrical. The hardest part about the installation was trying to remove the harness clip lol....
jmitchell
I agree, especially with a little dirt those harnesses stick tight. I have probably un-done mine about 50 times now. These must work exactly like the Yukon's tails then with LED's for the turn signals and brake lights. I am guessing then, that if they produce these to work with Tahoes they will have to install a resistor in each. Since Tahoes work with just incandescent bulbs except the night running lights for the tails. However, the video you posted does show a Tahoe with them....hmmmm.
luigasca
luigasca
Yes these light sync right in with the truck. Actually the people I bought these from make them especially for the Tahoes as well.
---------- Post added at 06:46 PM ---------- Previous post was at 06:44 PM ----------
And work just like they are supposed to. Nothing needed just plug and play.
bourgeois
Install the lights and they are going crazy. Both blinkers come on at the same time and they blink fine for a second and rapid fire.
I have plugged and unplugged the repays but no luck. Any help??
bourgeois
Relays?? There was none. Is yours for the yukon or tahoe? Picture of the relays plz.
I have a Tahoe. I'm guessing it because of the led of the tail lights. The lights are not worked correctly. I tried hooking them up different ways but no luck.
Blinkers blink togethers, brake lights don't work when the headlights are on and etc.
waiting on a call back from Vland regarding the issue
There were 4 relays,adapters with the lights
PD2770
