Esky with Airaid Intake/BBP Tune: Check Engine/Stabilitrak/Traction Control Issues
felixgun
Lafayette, LA
OK... so I have an 07 Esky with BBP Tune and AIRAID Modular Intake Tube... everything has been fine since I got it all put on but now I have the Check Engine light on, and Stabilitrak/Traction Control is off. I'm bringing to the dealership late next week when I get back in town but I was wondering if any of you have had any similar issues and if any of these issues might be related to the AIRAID MIT or BBP Tune? I'm guessing I should also tune computer back to stock before I bring to the dealer, yes?
GalaxyBlackEsky
BlackedoutLT3
MD
Go to Autozone or something and have them read the code if you don't have a scanner. It could be just a Emissions issue. Also off topic and sorry. How do you like the tune on the Escalade? I am thinking about doing this summer.
felixgun
felixgun
Lafayette, LA
Thanks Brent. I like it. Especially combined with the airaid modular intake tube. I still need BBP to do another retune on it bc the shifting isn't very smooth going from 2nd to 3rd gear. Just haven't had the time to do the re-log yet. I like it much more on the Esky then when I had it on my 08 Tahoe.
Marioski
IL
Felix,
There have been a few recent threads about this same setup and CEL / stabiltrack / 4wd messages going of and all have had an Airaid MIT tube. I am willing to bet its code P0172 (rich or lean conditions). Before heading to the dealership, check your MIT tube tube. It's been popping off the MAF sensor or the TB sensor setting off a vacuum leak.
Sent from my iPad using Tapatalk HD
---------- Post added at 08:20 AM ---------- Previous post was at 08:19 AM ----------
http://www.tahoeyukonforum.com/forum/showthread.php?t=57032
08grey
2-3 is hard to get right on the 6.2 with 6 speed. I asked Justin change mine several times. He can do it without a relog just describe well what your feeling. It's in the torque management rpms when shifting. Mine holds 3rd a little longer by request to stop the banging from light to light in moderate traffic.
Use your autocal to pull the code.
Ben
PCB, FL
Need to clean the MAF sensor and also your intake tube might of came off the throttle body
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Keep us posted with the code. Stabilitrac/tc is not controlled with the tune as it is in the ABS computer.
Sent from a jelly bean.
Blazed
Accepting Donations
Be willing to bet money on the MIT.
mine pisses me off about once a week
my2013
