Everyone's mods?
smyrna13
Wesson,MS
Just curious, wondering what all mods alot of you guys have done to your hoe?
so far on mine,i've just got edelbrock headers, with true dual flowmasters with no cats, a 3 inch body lift, and some 31.5 inch allterains. Soon to come i'm planning on a mild suspension lift and 35's. And I'm considering a BB tune.
Looks wise I have a cowl hood, gmc billet grille, and aftermarket lights all the way around, and a smoothie bumper
DJTricky
Banned
Robbinsdale MN
are we doing an "all mods list" if so here is everything to my hoe
Interior:
-custom door panel's
-custom box.
-custom wood accents
-custom lighting in sub box and headliner
-custom center console (holds the epicenter, hifonics line driver, and MA EQ, along with switches for full power amp turn on and light over ride)
-blue neon under dash
-blue neon under seats
-blue limo lights on headliner
-blue courtesy lights
-blue neon in sub box
-blue neon under rear seats
-blue dash led's
-custom switch panel
Exterior:
-all side molding removed
-debadged
-grill guard (winter only)
-blazer fog lights (winter only)
-police strobe lights front and rear
-4 blue led's in the headlights
-4 blue led's in turn/parking lights
-blue led bar (36 inches) in grill
-hyperwhite headlights 100 watt (high beam)
-6000K hid's (low beams)
-2 blue underglow kits
-bushwaker fender flares
-euro clear headlights
-euro clear corner's
-euro clear turn/parking lights
-euro tails
-all led turn signal lights (white in front)
-all led tail lights (red and white reverse)
Engine:
-stroker 383 with forged internals (10.5:1)
-high flow CSFI Vortec Spider
-full blown motors twin fuel pump set up
- 2 X 255 fuel pumps (corvette pumps)
-comp cams mild street cam
-CFM-Tech Ported Throttle Body
-CFM-Tech High Flow Throttle Blade
-ported heads
-2.5 inch cross over pipe
-hollowed out cats
-gasket matched exhaust manifolds
-4 inch aluminum intake
-MSD ignition system (msd 6AL)
-MSD distributor
-MSD 65,000 volt ignition coil
-MSD 9 mm plug wire
-E3 diamond fire plugs
Suspension:
-3/4 kit
-DJM shocks
-all poly bushings
-285 ELITE rims.
In Car Electronics:
-4 - 6 1/2 inch Phoenix Gold component system
-2 - 5 3/4 Phoenix Gold inch component systems
-2 Phoenix Gold ZPA 0.5 amps
-1 Phoenix Gold tantrum 1200.1
-1 Phoenix Gold ZXti475
-alpine deck
-alpine cd changer
-5 optima yellow tops
-12 - 10 inch MA Audio MA100XE subs
-all phoenix gold wire
-Phoenix Gold TBA1 line driver and EQ
-audio controls "the epicenter"
-hifonics XI-BLD1P line driver(sub line)
-police radio scanner
-built in radar detector and blocker
Brandon X
Michigan
Holy SHIT DJTricky. That's insane. I shouldn't even bother posting mine because it doesn't even compare to a list like that but here it is anyways:
Engine/Exterior:
Pacesetter Longtube Headers
Custom True Dual Exhaust w/ Moroso Spiral Flow Racing Glasspacks
Spectre Cold Air Intake
Black Bear Performance Tuned PCM
Undercoated w/ Herculiner
Optima YellowTop Battery
Removed Cat & O2 Sensors
Black Bowtie
Running Mobil 1 Fully Synthetic Oil w/ Tough Guard Fram Filter
Audio:
Kenwood eXcelon KDC-X693
3 Kicker Comp 12's in Ported Box
Kicker ZX750.1 Amp (Subs)
Kicker KS650 front and back door speakers
Kicker KS4100 rear roof speakers
Kicker ZX650.4 & ZX150.2 Amps (Speakers)
XS Power 2400w AGM Powercell Battery
Raptor 0g Wiring Kit (distro blocks, 200 amp fuse holder, terminals, etc.)
DJTricky
Banned
Robbinsdale MN
you know im actually thinking about picking up another hoe and starting all over, like a 2 door 2 wheel drive, doing a sub wall, and some other stuff
T-Bagg
The Esca-Hoe driver.
Doesn't Matter
Cadillac front clip
Full K&N intake
Jet Performance MAF sensor
Jet throttle body spacer
Hypertech power programmer
DynoMax dual exhaust.
3-inch body lift
Bilstein shocks
Weld racing wheels wrapped in Nitto Mud Grapplers
Pioneer head unit, Memphis audio for the amps and speakers plus two JL Audio 12" subs
After I get my tax return:
The 2 12" subs will be swapped for a single 10" Memphis audio sub
A 6" inch lift by RCD
CV shafts by RCV Performance
The Mud Grapplers will be swapped for Nitto Trail Grapplers or Toyo Mud Terrains(haven't decided yet)
****** Truck Force headers
Roof rack with lights
Westin Bull guard
The ignition will be replaced with MSD components
Considering camming it.
(Yeah, I'm getting a big tax return)
bowtiefreak
No Quarter
Near Philly
Let me start with, the frame is untouched. I put all the money into my motor, my lift, wheels, tires, brakes, light upgrade on the radio and speakers.
Motor: HT383E with custom tune
Suspension: DC 6.5" front, procomp 6" rear springs, quad bilsteins up front
Wheels & Tires: AR Mojave teflon 17x8, Procomp Extrme AT 35/12.5
Brakes: SS lines, power slot rotors, Hawk Pads, ABS bypassed
Exhaust: JDA headers, Magnaflow cats, borla cat back
Intake: K&N FIPK
Look pretty items: cowl hood, debaged everything, manic brush gaurd with KC lights, TYC head lights and marker lights, custom front bumper with billet inserts, billet grill, middle finger air freshner, tinted windows.
I think that is about it
Gears: 4.56 yukon with True trac out back
Protection: Glock .40....and many more
foreverfalcon40
O Geez I should type it out and save it....list is tooo long I'll get back to you on that.
BlackedOutHoe
Low & Slow
S. Carolina
For me:
Interior:
Custom wrapped door panels.
Denali cluster
LED's in HVAC, cluster, courtesy and dome lights
Stereo:
Jensen in dash DVD
infinity front and rear speakers
4x6 blaupunkt's added in custom box under back seat for more speaker range
Razor audio 15" in custom ported and tuned box.
Autotek 1000 amp.
Exterior:
6 inch RCX suspension lift
2 inch PA body lift
17x10 gunner 6's on 37x12.50 BFG KM1's
windshield tinted 35%
front windows tinted 20%
Goodmark steel cowl hood
tinted tails and corners
color matched grill and green bowtie
Front and rear bumpers painted black
Front HD bumper w/ fog lights
5000k HID's in lows.
painted handles
Roof rack pads
custom raised bumper for BL
TYC clear heads and parking lights
Engine:
AEM bruteforce CAI
No cats
Magnaflow 3" to a 5 inch diesel tip
4.88 gears
foreverfalcon40
O boy...
PROTECTION: Prestige Alarm with Auto Start and LCD Pager. If the Alarm is Set off the Pager Buzzes in its own over protective psychopath protecter armed to the TEETH!
Exterior:
OEM 00 Escalade/Denali Front End
Good Mark Steel Cowl Hood
Clear Corners
GT One Piece Headlight Covers
Fender Flares
Sir Micheals Steel Roll Pan
Deleted Roof Rack
SoCal Customs Smooth Wiper Cowl
Led Tailgate Light Bar
Billet Grill Painted Black
Chrome Rear Diff Cover
AVS Window Shades
Interior:
Painted Dash and assorted Interior Pieces. OEM Gray Interior with Leather assorted pieces are painted Black
Electonics:
Pioneer Double Din Avic D3 with Ipod Cable and B-Up Camera. Had to Hack up the dash
Kicker Speakers thru out the Truck (6) total
Custom Amp Rack underneath my rear seats.
6.0 Power Acoustic Farad Cap
600 or 800 watt Pheonix Gold Mono Block Amp
1,000 Watt 4 Channel Power Acoustic Amp with Plasma Screen
Kicker 0 Gauge Amp Wiring Kit
BLUE LED CLUSTER
Autometer Gauge Pod with a Cobalt Series A/F Guage
LED Door Lights
Removed Auto Dome Feature (when you open my doors it stays BLACK...no light)
Air Horns
8k Hids in Headlights (Blue, but dont do any good b/c of GT Headlight Covers, will be installing HIDS in my Fogs)
%0@
Suspension> & Brakes!3A
Bilstein Shocks
3 1/2in Torsaon Key drop-20in the Frcnt
2in Dvopped Rear
Stainless Steel Brakelinew Front and Rear
Caliters and Drums Painted Silver
Optima Yellow Top
Wheels:
Winter Boots> 15" Aguza's on Cenergrabber UAP All-Terrain)20Tires
Suemer Shoes: 22" Chit Foose Speeders Powder Goated Black(with Chrome FOOSE Center Caps, Studs Removed wiph 2 differebt type of$Lug Nuts Everyone One`is Chrome cr Black froa American Recing) Toqo Proxies if the Front`and Sumotomo's in the%>0Front
Got Vortec?
Stage 1 Heads: 3 Angle Valve Job, shimmed Strings, Soli` Rockers
TB Spacer
%<AVolant Intake wath the 4"-20Collectov had to%>0some fabbing-20to make it work with`the TB Spacer
3" Oibson Cat-Bacg Exhaust
MSD Coil
MSD 6-AL Ignition Box
B&M Shift Kit
E3 Plugs
Posi Rear
All of this Tied intogether with a BLACK BEAR IN PERSON TUNE FROM JUSTIN!
Upgraded 1-2 Shift, All Compression in Valves bumped up as well as fuel tables pending throttle percentage
FYI: Only Use Mobil 1 Synthetic or QuakerState 4x4 Synthic Oil and ALWAYS A FRAM FILTER! Every 5k miles!
Waiting to be Installed as of summer when it gets warm out...
HIDS in my Fogs
Whipple S/C Kit
Headman Ceramic Coated Long Tube Headers
2.5" SS Custom Exhuast thru a Bullet Crossover X Muffler
Autometer Cobalt Series Boost Gauge, Tranny Temp Gauge, W/B
Tranny Cooler
CFM Tech High Flow TB Blade
Damm I need clean out my room : )
Dieseldr
