Exhaust/fuel injection ????
*HEAVY-CHEVY*
I recently had to replace my cats. I talked to multiple exhaust shops and they all told me that I cannot cut out the cats and weld in 2 new ones or it would throw the same code within a few months and also cannot install anything other than shorty headers as far as aftermarket. So I ended up spending $600 that I didn't have to replace my pipes from the manifolds back to the muffler. Then within a month I have the same code coming up. I believe it is p0420 for egr. After having it closely monitored on a computer for fuel pressure and such they tell me something is wrong with my fuel injection and I am only getting single digits on one side and double what I should in the other! My 97 Tahoe with almost 160K runs better than any other one I have ever driven! So a couple questions:
1. Anyone had any issues installing high flow cats?
2. Anyone encountering problems with fuel injection? (example. lines clogging and cracking)
3. Do I need any special tuning after installing both long tube headers and highflow cats?
fyremanpat
Fyremanpat
I had the same problem. I replaced all 4 o2 sensors..still had it. I put the magnaflow hi flow cats on...still had it...I cleaned my MAF...problem solved. If it cant read air flow accurately its not gonna burn right in the cylinder. Get a can from the auto parts store and try that.. good luck
p.s. make sure its MAF sensor cleaner! anything else can leave a residue
retorq
Kingman AZ
You replaced exhaust because of an EGR code??
I don't see how a high flow cat will throw a code either ... sounds fishy.
fyremanpat
Fyremanpat
P0420- Catalyst System Efficiency Below Threshold (Bank 1)...can mean a number of things.
# An oxygen sensor is not reading (functioning) properly
# The engine coolant temperature sensor
is not working properly
# Damaged or leaking exhaust manifold / catalytic converter / exhaust pipe
# Retarded spark timing
# The oxygen sensors in front and behind the converter are reporting too similar of readings
* Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required.
* Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady).
* Inspect the downstream heated oxygen sensor (HO2), replace if necessary
* Replace the catalytic converter
---------- Post added at 11:46 AM ---------- Previous post was at 11:46 AM ----------
http://www.obd-codes.com/p0420
H
*HEAVY-CHEVY*
So i jumped ahead cause I was told my cats were bad. I left out the part where i went in and had a Cherry Bomb "Vortex" muffler put on and it was very quiet. I was told flat out that my cats were Burnt.I then put all new exhaust on including a cherry bomb "extreme" after replacing them I am getting the same code!
As For what "Fyremanpat" says I pulled the little screen out of the maf sensor when I first got the vehicle thinking I may be able to breath better. I guess there could be some residue in there from condensation or something?
---------- Post added at 08:25 PM ---------- Previous post was at 08:22 PM ----------
Well if you throw a high flow cat in and all of a sudden your o2 sensor is getting a much higher flow I believe it is going to think something is "fishy" too. Kind of like elimination the cats all together the o2 sensor is going to notice it.
retorq
Kingman AZ
I was thinking the single sensor in front of the cats like my TBI. Sorry carry on. :D
slomo26
Charlotte, NC
I'm getting this code also (P0420). I drove around for about an hour with a scan tool plugged in trying to see what my 02 sensors were seeing. The readings from bank 1 sensor 1 were almost identical to Bank 2 sensor 1. The same with the two downstream sensors. Since Bank 1 and 2 are identical pretty much It makes me think its not the cat or the sensors. Am I on the right track? By the way its a 99 2 door Tahoe. Thanks for any help.
bowtiefreak
No Quarter
Near Philly
I have high flow magnaflow cats with no problem. Try cleaning the MAF and the EGR.
gmtech
New York
The main thing is to not spray anything right on the wires do like a light mist and take a small pick and lightly scrap the wires to get anything off then lightly spray some brake cleaner on them and let dry and that should do the job :Handshake:
shadowid60
