DuraYuk
- Joined
- Sep 17, 2022
- Posts
- 854
- Reaction score
- 614
If you are leaking exhaust into the engine bay you will have codes and live data to go with it. Its not unheard of for techs to make up steps in the diagnostic process to make a quicker repair.I don't think you guys are understanding the course of events.
Issue 1: When the engine was running, exhaust smell happening in the cabin. If you got outside and opened the hood you could very clearly smell untreated diesel exhaust (not regen small). This was diagnosed as a leaking turbo via GM's smoke test procedure. (This exhaust was being sucked through the cabin air filter into the cabin)
Issue 2: After the turbo was replaced; continued to get an exhaust smell at startup (only in the cabin; for say 1 min). Tested the system for leaks, none found. They pulled the cabin air filter, it was stinky (from the previous untreated exhaust going through it). Filter changed, it doesn't smell now.
Issue 3: Check engine light, emissions, ect, sensor on turbo failed. They replaced the sensor and now those messages are gone.
A cabin air filter cannot be the root cause of an exhaust smell within the cabin. Changing a cabin filter will not fix an exhaust smell issue. Their has to be a leak in the exhaust system to get an exhaust smell into the cabin. (I'm not taking about regen smell, I'm taking untreated diesel exhaust smell)
As a tech i could tell you anything to validate why I did what i did. They also have to write that in their story that gets turned into warranty.
I'm glad you got ot fixed but something is missing from your story. And it may not be up to you to know as you only know what they told you.
The chain of events doesn't make sense to me. If your getting smoke coming out of a turbo there will be more happening then just a smell.
The fact that you actually got codes later that was blamed on a sensor corroborated a leak being introduced after the fact.
Like i said earlier no way to definitively know since we were not there but as someone experienced in the business and fixing comebacks from techs it is what it is.
If your happy and the car is well thats the end of the story.
