Extra 1" of drop. How to.?
BigMex
San Diego
I recently installed 3" lowering springs with relocators on my Yukon and was wondering if in the front I could just get one inch of drop out of the stock keys?. I don't want to go lower in the front just wanna level it out and right now I'm about the inch higher up front. Are there any issues with just cranking down the keys to acieve the drop?
Thanks, Adrian.
chistoso
Arizona
Are you just trying to get 1" overall from stock using the stockers or did you use drop spindles and wanting 1 more inch? I've heard that if you decrank the stock keys you will achieve a mild drop but ride will suffer. I'm sure someone with more knowledge will chime in soon..
blueflamed03
Oklahoma
PM a memebr MAX on here, he can dial you in with some Ford keys for cheap that you can lower more safely than cranking down your stocks. :)
did you change rear shocks on rear?
BigMex
BigMex
San Diego
Thanks. I used the existing shocks but the truck has 120k on it and looking into a new set of Bilstein shocks in a month or two.
I'll search for "Max" . Thanks.
BigMex
BigMex
San Diego
Yeah, so it's not possible to just lower it with the stock keys without affecting the ride?
chistoso
Arizona
You will definitely have to get it aligned if you decrank the keys. You'll probably get a little lower but the ride quality might suffer. I've heard the turning radius will be stressed the tighter you turn as well.
BlackDenali
Roof Rack ****
Boca Raton, Florida
my brother did it on his escalade and he got about an inch and a half out of the stock keys.the ride hasn't really changed :imo: but everyone has different experiences and results! Isay do it and post the results, if you have any problems Max is the man to get a hold of!!!
gringoloco
Ride quality will suffer since you're effectively changing the spring rate. 'Purple' keys allow you to drop that inch while maintaining the same tension on the torsion bars. You will need an alignment either way...
R.Beezy
Costco Member
Bay Area 510
i say best way to go is get some Belltech Drop Struts... adjustable from -2 to +2 inches
CdnDenali
What year/model 2500 hd pick-up are they from? All my parts are almost here....Heading to the salvage yard this week-end to find "purple keys".
Maisie14
