factory DVD + aftermarket stereo
frankenstien
Fairbanks, Alaska
just had an aftermarket radio put into my 06 yukon denai, just seeing if anyone has found a trick or something to get the dvd player to play through the aftermarket stereo which is a kenwood dx 771 i beleive. stereo shop says only option is to get an aftermarket one that has an fm modulator in it to get it to play through the stereo system, i believe them, i just thought id see if anyone found a way around it.
thanks
F
frankenstien
Fairbanks, Alaska
thanks! so that does the video and audio? or just the audio? i am not super famillar with the stereo stuff these days, my main goal is just getting the sound through the system, although video and sound wouldn't be bad either
NathanJax
Vacation Nathan
Administrator
Jax, Fl
video and sound if you get the right harness. that thread explains it all
F
frankenstien
Fairbanks, Alaska
ok, ive read it about 3 times, and i think im getting it, sorry im a little slow at this.
Yes, your missing something. IF your OE radio was the source of activating RSE (by hitting the source button) you can use this harness. If activation was somewhere else like the rear controls, then no you can't
Meta GMOS-014 - GM Onstar/ RSE/ and retain the warning chimes module
The GMOS-014 is designed to retain Onstar/ Rear seat entertainment (RSE)/ and retain the warning chimes that are normally lost when the OEM radio is removed. It also provides a 12 volt accessory output for aftermarket radio operation.
The GMOS-014 provides a mute/ parking brake/ vss or speed sense and reverse output to make installing an aftermarket navigation radio simpler and less time consuming.
i read the description online, my truck originally had the navigation radio, so to get the sound from the dvd player over the radio speakers there was a button for it,(had a cd on it) is that consided activating the RSE from stock head unit? as the truck also has a control in the center console that lets you change the source for the headphone jacks.
to me it sounds like this GMOS-014 should work for my application,
NathanJax
Vacation Nathan
Administrator
Jax, Fl
For your factory radio, you had a button you could hit to switch directly to RSE... but could you also hit the source button and scroll through your sources until you got to (or heard) the RSE? If so, then yes... and it's the most likely choice as well
harlamert
