cmhorns
- Joined
- Aug 2, 2020
- Posts
- 28
- Reaction score
- 14
Anyone have a speaker locations map or diagrams for 2018 Tahoe z71? Or even a list of locations and total?
lol nah, mine is special, at least to me, but not that special! I think escaladers are supposed to go to the "bourgeois/bigmoney" site or something like that right?
thanks I will try to get some info from them, if anyone has info on it, I bet they do for sure!crutchfield com might have some good images with the locations partially dismantled also.
if you want size's and things like that then yes crutchfield shows all that, if you upgrade the speakers it likely won't sound the same because the oem amp and speakers are usually not common ohm's so instead of 4ohm's it might be 2.7 or something else, the fix of course is to just do the whole system, speakers and amp(s) you can make it work with the stock headunit if you really like it. if not then you can use a maestro rr and that will allow you to integrate a aftermarket headunit in and still have the oem functions.thanks I will try to get some info from them, if anyone has info on it, I bet they do for sure!
generally people who buy escalades don't fix their own carlol nah, mine is special, at least to me, but not that special! I think escaladers are supposed to go to the "bourgeois/bigmoney" site or something like that right?
