Fast Idle
96-2D-Hoe
My truck is sometimes idling at 700-750 rpm after it's warmed up. If I'm driving for 20 mins I'll notice it once or twice. Normally idles at 600 rpm.
I've never changed the IAC valve, I did cleaned the MAF sensor and the throttle body a couple years ago, air filter is K&N and clean. Truck doesn't go far and It's probably done less than 5k miles since I cleaned everything.
Any ideas?
Thanks
Big Mama
Virginia
Usually a high idle is extra air getting in somewhere. With it being 100-150 higher it could be as simple as the weather. Check your vacuum lines and the intake clamps
96-2D-Hoe
96-2D-Hoe
Was idling low around 550 when I pulled into my parking space after driving around for 45 mins last night. Headlights were dimming until I touched the accelerator. Have been meaning to check fuel pump pressure but I don't think that's it.
96-2D-Hoe
96-2D-Hoe
I broke the hard plastic hose going to the evap canister when I swapped out the steering gear. I'd used a rubber cap with the top cut off as a straight connector but it's fallen apart for some reason, probably was too tight.
Still haven't driven it yet though :)
96-2D-Hoe
96-2D-Hoe
its usually better when it tight
It was from a vacuum line kit I've had for 20 years. It was very tight, i had to lube and force it together. It had split all the way across. I just left it on and taped it up with electrical tape for now.
