Two coupons worth mentioning for advance auto right now
Code - P20 - 20% off
Code - AP55 - 15% off + $50 next order of $100+
Use both of them at checkout and you will get 20% off order and the $50 coupon.
The coupon is only good for a little over a month, so buy everything you need now and then on your second order spend over $100 and use your coupon.
A quick comparo for my 5.7L OBS:
This site is REALLy easy to navigate for the parts needed for a Tune-up...check "Ignition & Tune-up" under the "Replacement Parts section"
Sparkplug wires are INSANELY expensive @ Advance, get them somewhere else.
I used all the AC Delco part numbers from Advance and plugged them into:
http://frugalmechanic.com
I'm personally going with Advance b/c if i split my order in two (using the $50 coupon), I'll come out ahead pretty significantly...minus the wires of course, those I'll get somewhere else.
Hope this helps!!
Hope this helps!!
