Hello I have a 2000 tahoe z71 gmt400 4L60E with 5.7L engine.
Upon braking, at the last 10% of braking, it feels like the brakes are "slipping". To be more specific, it feels like the caliper lets go and then reclamps, sometimes multiple times, just at the very end when the truck is almost to a complete stop.
There is no problem stopping from speed or stopping hard, but if coasting to a stop at like 20mph it will do this shudder kinda thing at the very end. Or if in a parking lot going slowly into a parking spot, it will kinda let go for a second and then finish stopping.
It's easily reproducible when applying the perfect amount of brake pressure. Sometimes it makes me wonder if the ABS is activating unnecessarily. It's almost like abs chatter.
---- Here is the catch... ---
Over the weekend I had all the brakes replaced. While under there they found a rear axle had busted a seal and flung grease everywhere, so I got pretty much a complete rear rebuild. Diff flush, repacked. Brake flush, bled, high temp fluid (as was before). New calipers pistons pads on front. New drums on rear. New brake hoses to the front (they were partially collapsed/squished). New battery (unrelated, it was due).
Picked it up figuring this would fix it, drove around the mall, I can still reproduce the original symptom. It's not as bad as before, and not as noticeable as before, but it's still there. Drive up to a stop sign at about 20-25mph. Press lightly on the brake pedal. Vehicle comes to stop. Last tiny bit the brakes feel like they release then re-grab.
Now I am getting worried - if it's not the brakes then...?
If it is the brakes then how did replacing everything not fix it...
