Felix's White on Tan Denali
08grey
Felix's Black on Black Esky and Black on Tan Avalanche
Does your aftermarket radio have a video output?
felixgun
felixgun
Lafayette, LA
Yes it sure does but it doesn't just work plug and play to an oem secondary screen.
Administrator
That seems odd Felix :think: why would it not be plug in play to a secondary screen? Even my buddies cheapo DVD head unit just plugs into a headliner DVD unit.
felixgun
felixgun
Lafayette, LA
Because it a factory overhead LCD drop down. I'm guessing your friend went from aftermarket radio to aftermarket secondary screen? I'm going from aftermarket radio to oem secondary screen. The guy that helps me do all my Audio crap tried to do it and said I specifically would need a third party interface to make it work.
Administrator
Interesting! And you're right. My buddy was going from aftermarket to aftermarket.
felixgun
felixgun
Lafayette, LA
Yep I figured that. And if I had an aftermarket overhead secondary screen it'd be hooked up by now... So basically I'm trying to figure out everything I need to get it to work like it did when I had my oem factory nav radio. I also read you need this extra module/interface for the infrared feature so the oem wireless headphones and remote will work too.
Administrator
Well I learned something tonight :) what a PITA!
felixgun
felixgun
Lafayette, LA
I know! He and another friend of his that works at our local audio installer around town tried for a while to get it to work to no avail. Then after some googling I found the PAC GMRVD interface cable made specifically for what I need. But after reading the description I'm confused as to if this works as a standalone or if its mandatory to be used with the PAC OS-3 which I don't have...
I have the OS-4 and have no idea if I can use that in place of the os3 it supposedly requires. Or if its required at all... I read the OS 3 description and it sounds like its exactly what my OS 4 does. Basically I'm confused as to what I need bc I can't find any forum threads about this exact situation.
---------- Post added at 10:36 PM ---------- Previous post was at 10:33 PM ----------
Link to the interface I'm talking about:
http://bit.ly/1bFLxwh
felixgun
felixgun
Lafayette, LA
Just ordered the PAC GMRVD harness for my avalanche. It's the interface needed to use the factory rear drop down LCD monitor with an aftermarket screen. I also ordered the Airaid Jr. 200-796 CAI kit for the Esky. The Esky will finally be getting the much needed BB Tune after the CAI is installed!!!
ehernande86
