fender flares
Donnie Yukonie
Yates Caretaker
ok so i went to the pick and pull today , and spotted a set of flares on a suburban i have a question i removed all the bottom screws but i cant pull it off i peeled it back and there seems to be screws holding the flare on the actual side of the fendfer but i cant see where to get to them. do i have to pull off the fender?
Tbruz
Windham NH
2 door Tahoe and pickup truck rear flares have access holes that pry out from the wheel wells; 4 places I recall. Once these plates are removed you can get to the nuts.
Front fenders, YUP, you have to remove the fenders to get to the nuts.
Check into the aftermarket flares that glue on the fenders and scre into the wheel well openings.
Tbruz
Gzes
the drifting 2dr
Wichita tx
Yea i would rather get bushwackers. If u want oem then have fun ripping the fender out and taking the bolts out. Time consuming and it sucks
Donnie Yukonie
Donnie Yukonie
Yates Caretaker
damn i mean i knew already i was going to either have to mod the suburban ones to fit for the rear of my yukon but by the sounds of it its not worth it . the flares are in good shape and the guy only wanted 25 bucks for them
slipping
Rosamond, CA
Get em , flip em
Donnie Yukonie
Donnie Yukonie
Yates Caretaker
Get em , flip em
i thought of this two only issue is if its even worth it on my time part i never took off a fender on these things should be like what 8 bolts 4 on top and 4 under the wheel well?
Roscoe2352
