FINALLY BUILDING!!LQ4 w/Ls2 Heads & Cam w/LSXR!!!!
t_ahan
Crofton, Md
finally i pulled the trigger and bought a performabuilt trans with 2500 stall tc ..and pulled the motor and trans so the LS2 Heads,LSXR Intake Manifold,Aeromotive Fuel Rails,and a 216 220 Duration Comp Camshaft with 1.72 ratio rockers and new valve terrian can be installed!!!....SO FAR WE TRANS IS OUT AND SHORT BLOCK IS BEING TORN DOWN !MORE PICS TO COME!!! engine parts.jpg
t_ahan
t_ahan
Crofton, Md
short block
about to tear down the short block and clean it up to ready for some fresh paint!!!!SHORT BLOCK.jpg
Z-56 Hoe
What do I do????
Houston
how much did You pick up the LSXR intake for? what kinda gains can You plan on getting from LSXR intake? is Your Block a LQ9 or a LQ4?
t_ahan
t_ahan
Crofton, Md
lq4 block ...and now doing pistons and rods
ended up getting some better pistons and rods to squeeze alil more power out of this setup...and as far as the lsxr intake manifold goes it should be around 15hp but im using with this setup to make sure there will be enough air to feed the ls2 heads with the cam...if i remember correctly the intake manifold cost like $1000.....as soon as all the parts r at the shop i will get some pics of what the complete set up will be with the intake manifold,fuel rails,heads,cam,rockers,lifters,pushrods,pistons and piston rods...and i will get the performabuilt tranny in there too! i hoping this motor will be putting out atleast 500hp
Probe Pistons 14510-STD - Probe SRS Forged Pistons
Eagle Specialty Products 6125O3D - Eagle ESP H-Beam Connecting Rods
Sealed Power ZE921K - Sealed Power Plasma-Moly Piston Ring Sets
Z-56 Hoe
What do I do????
Houston
ok I'm asking because I'm having mine done right now LQ4 with Dimiond Pistons, custom Rods, a 227-235 cam with 114 lob and 614-620 lift, with PACK 1518 springs, and Titanium retaining clips.
t_ahan
t_ahan
Crofton, Md
it may or may not be worth it....but from what ive read the lsxr should def help ....i dont see how it could hurt performance ...jus comes down to how far deep u r into it....sounds like ur ganna have nice setup! any pics of the build?!
ATL
im interested to see how the ls2 setup compares to the L92 setup hp wise. what is the casting number of the ls2 heads? L92 heads can be bought for about 600-700 new and flow around 320. they make 550hp on a lq4 with a matching cam and ls3 intake.
im not sure how the ls2 heads compare. as far as i know, a ls2 is basically an all aluminum lq4. lq4s and lq9s have the 317 heads, which are VERY similar to the ls6 heads, only difference being combustion chamber. so if thats the case, i dont see how the ls2 heads can be any better than the 317s. i can point you to an article about makin 480hp with the 317s and stock shortblock if interested
steezy5oh
