Finally done with esky 2/3 vs now
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
id just shorten the links try that first
KMeloney
My links -- with the spacers still in -- are as short as they can go. Any shorter, and the left one pops off and throws a code. Lots of trial and error to get them where they are.
I'm wondering about the ride and whatnot with the spacers pulled.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
all you need to do with the endlinks is jack up the truck and make it 1/4 inch longer then when you get full extension from rear end. that way they never pull out also 10x24 machine screw.
if you need it lower than what it is now and you hve the endlink to the shortest position pull the spacer and just make it 2.75 inches long and start from that point
KMeloney
Maybe this is the better question, Tony: will I get a better ride with longer links and no spacers, or with shorter links and spacers? Or, will it be the same?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
this is one of those things you will need to try. I like a stiff ride ie more air in bags. Pullthe spacers out and let her rip
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Yes. im thinking abotu 295 35 24 now though. When loaded up with people front just rubs on bumps
shundal
NorCal
Tony, let me know if you are thinking about selling your 305's if you switch to 295's. I could use a set for my spare wheels.
elliotte08
