RooTBeeRthe1st
- Joined
- Jul 11, 2018
- Posts
- 1,143
- Reaction score
- 2,617
I did get the whole set of lines.Looking good! Question - did you install the PowerStop brake lines part code BH00161 (like $150 for the set)? If so, on RockAuto it says for those that they're for the smaller rear differentials "with 10 bolt hole cover" (the 8.6" rear I think?). Is that the rear diff you have?
I ask because my truck has the larger 14 bolt hole cover rear diff (9.5" rear I think?), just curious if these would still work despite that note on the RockAuto website.
And just over a year ago now, I broke the 8.6 and got a 9.5 out of a Cadillac and put it in.
Literally everything bolted and connected right up.... Now that I think about it, I may have left all of the rear brake lines from the 8.6 on the truck when I dropped the axle out because the wrecking yard had cut a bunch of stuff off of the 9.5 and I probably didn't want to bleed the brakes. I'd have to take a look at my old diff and see if I left the brake lines on it.
Although I also have a 1 inch lift spacer in the rear springs so I believe I bent the bracket that holds the hard lines to the soft lines on the top of the diff just to give myself a little more clearance so they aren't under tension at full droop.
