First experience with headlight removal...
Polaris425
SO... It aint easy getting to the bulbs to replace them on this thing. (2009 Tahoe LT).
I took the two top screws out, started pulling, the top seemed to pop right out but something below was catching it. After wiggling and snatching for a few minutes I grabbed a flash light and started looking under the headlight pod. Yep, a tab that tucked down behind the bumper...
You have to take the freaking bumper loose, just to get the head light out to replace a dagblame bulb? Geesh...
Not any more. Hacksaw blade. That tab is gone now. Light popped right out (sort of). Replace the bulb, and slapped her back in. Put the screws back in, and she doesn't move at all. So I'm not real sure why that stupid tab was down there. Being removed definitely hasn't affected the headlight pod at all.
08HoeCD
I fought with my passenger-side headlight assembly for about an hour before finishing up replacing it, and I had step-by-step instructions. lol
Polaris425
Polaris425
LOL! Does it bounce when you hit bumps?
It does not. I pushed on it and tried to make it move, and it doesn't. There are other little tabs back there (the pin style) that line it up and keep it steady.
I swear GM does stuff like that just make people have to go into a dealer to have even the simplest things replaced. Screw that, that's what hacksaws are for. lol
adventurenali92
Big Bear Lake, ca
I must say as an owner of an earlier model I'm not all that impressed with GM's designing department on the newer models. My 2006 denali headlights have to long metal pins, one on either side, and they pop right out. It took less than 5 minutes replacing bulbs in my headlights last time around. But then again my headlights don't sit in the bumper. So maybe that's why. Lol. But I agree to have to loosen the whole just to replace a headlight bulb is the stupidest thing. Stupid design.
Chetrick87
I thought there was a bolt. And that you have to loosen uo the wheel well and reach in there to loosen it. I think previous owner broke it so i just had to do the 2 bolts. But one of them does bounce a little when i hit bumps
TheAutumnWind
Love the headlights in my NBS. Takes longer to pop the hood than it does to remove the headlights.
1BrittanyCarr
