Five lug to Six lug
L8RH8R
If this had been discussed before then forgive me. I want to run 20" six lug factory wheels on my 1999 two wheel drive and don't want to use spacers. As for the front, are the front rotars a simple swap out? And for the rear, can I just swap axle shafts? As always thanks for the input.
retorq
Kingman AZ
You won't run spacers you will run adapters. There was a thread about putting 2500 non4wd rotors up front and swapping the rear. Finding alxe shafts to fit the existing rear was not that easy. There was soem from an older Blazer that were about 1/8th difference but that was a long time ago and I don't recall the exact year or anything ...
L
L8RH8R
I meant to say adapters. Thanks. My quest marches on.
patniven
