Fix Oxidized Headlights
Yukongk
NY
If it hasn't been mentioned, I restored lights that were worse off than yours with a 3m Kit from auto zone. It attaches to a drill and comes w all the sandpaper you will need.
I would coat them with a permanent coating like Opticoat (the headlight coating, not the regular paint coating) and you will never have to redo them.
CHUBBFRESH
I just read somewhere that they used toothpaste n two rags and brought their headlights back to life...I'll try and find the link
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
True Brand headlight restoration kit #t601
This is by far the best kit out there. I have probably done over 300 vehicles myself with this product. (Used car department of a Honda Dealership).
The buffing and clearcoat method is flawed. It will look good for a while but the will yellow again.
This stuff is basically a wetsand and clearcoat process but replaces the UV coating you remove when sanding with a superior UV coating in the clearcoat you apply afterwards.
It will make yellow oxidized headlights look just like new again if done correctly.
The shop I work at now was doing the buffing method and it really doesnt even compare. I showed them the method I used and it was night and day. Crystal clear clarity.
JesusArTorres
JesusArTorres
Tulsa, OK
Thanks for the help and suggestions. I went ahead and got a Megiuar's kit and I was happy with how it came out.
BEFORE:
AFTER:
---------- Post added at 05:06 PM ---------- Previous post was at 05:05 PM ----------
Should I still clear coat it though or leave it like this?
BlackBettyBurban
