98blackbell
Well a/c quit. Got one of the quick fix kits at autozone. Pressure was low.
I had to straight wire the compressor to get it to kick. Got the pressure up to required level and re-plugged the compressor switch still did not click on. Did ohm test on the low pressure and had no continuity with switch plugged in. Tested the plug and grounding out the plugged fired the clutch on the compressor. So, $11 low pressure switch and I have ice cold a/c again!
