Drivers side valve cover
opfor2
Riverside County, CA
Is there any way to determine if my 2011 has the new improved valve cover per GM TSB# 10-06-01-008M without actually removing the cover?
You might be able to tell by the pcv hole location, maybe..... You would have to compare a photo of them side by side and not sure if you can tell from the topside or not
When was the truck built? If memory serves, the new valve cover design was introduced in March 2011. Search the forum or GM TSBs to be sure.
The part number for the new one is 12642655 for 2009+. The earlier years use a different diameter PCV and consequently a different part number.
opfor2
opfor2
If I go by the emissions sticker that is located on the driver's side door it has a date of November 2010, so I think I'm in need of a new valve cover.
donjetman
bdewitt205
