Fixed Dim PRND31 dash light - how to zero the trans temp
Sdp1234
Southeastern PA
thanks to all who shared the procedure for removing dash, instrument cluster and resoldering to fix the dim lights. I had a couple regular lights on the panel that are out. I’ll have to fix them next time. What bulbs are folks typically using?
I removed all the analog gauges and didn’t mark their locations. I was able to find a way to check, Mph, engine temp, rpm’s, amps and oil pressure. I have no way to test transmission temp to adjust gauge without buying an expensive tester. I guess I’ll just have to zero it in based on starting position unless anyone has suggestions
S
Sdp1234
Southeastern PA
Posted this to the wrong forum Any way to change it? Should be in the 2004 forum
chevius
