Flasher module issues
not_panda
New Jersey
About a week ago, I noticed any time I put on my left turn signal, my hazards would come on. So I then ordered a new flasher unit. Once I installed today, it fixed the problem, but created a new one. Now every time I put either turn signal, the flash twice, maybe even three times the rate at which they used. Any insight would be much appreciated
not_panda
not_panda
New Jersey
The original part number was gm #15764135. I Replaced it with ACDelco #10383320. That was recommended with the heavy duty trailering package (VR4) which my truck has
LaOrange
River Ridge La
Hi
Are you using LED Bulbs ?? If so there is an updated flasher
that is compadable for low draw LED bulbs The model number
at least for my 2004 GMC is LM487 which is LED compatible
not_panda
not_panda
New Jersey
No, I'm not using LED bulbs, I'm just using the standard bulbs. Most of the research I did was referring to that, but thank you.
kevinwhite
