SnowDrifter
- Joined
- Sep 5, 2016
- Posts
- 2,445
- Reaction score
- 2,688
Iirc there's a tsb about adding a second magnet
I tossed some neodymium mags in mine
I would say about 30 or 50k miles ago, so would it be best just to change the fluid and filter? It doesn't look burnt up at all just brown with a tint of red.
Hey all, I am curious that fluid is brownish/red after only 30-50k MLS. My last vehicle went 100k and fluid was still pink/red w/o brown color. Did it actually get rebuilt?
Just seems odd to me as I had a place rebuild my TH -350 25 years ago and it wasn't rebuilt, they lied and just changed the fluid so it looked clean when I picked up, a couple thound miles and was dirt brown again. Cost me $350 and couldn't find them as they got fired for scams. I was a kid too so lesson learned.
I changed mine when I 1rst got 03 Tahoe 5.3 by changing filter and pan fluid first and then got a hand pumps desighned for tranny fluid that pushes & pulls fluid twice a yr w/o changing filter. The pump (I think it is a Mytvac) that you push a thin tube down the dipstick tube and it sucks it out, mark the vac tank, refill with fresh fluid and push into trans. Works great for the price ($75) and have been doing this for 5 years.
Going to change filter on next change and expect a clean...ISH filter.
Good luck buddy. :^)
I eventually got around to do it, I had final exams so I didnt have time then. What I did for now was I changed the filter and replaced the fluid that came out. I also realized I had a leak in one the lines so I had to fix that too.Hey, just wondering if you ever got around to the fluid change and how did you do it.
Don't even need to pry it IMO. Little cheesy
Just reach on top with a torx and a small ratchet and undo the bracket
