Fog Light Adjustment
Thrust
ICT
Maybe this helps?
petethepug
Michael
SoCal
LED bulbs must be designed by the the bulb housing MFGR or vis-à-vis. The bulbs are essentially mounted on a projectile or stick. The best way I can describe why it won’t work is the picture below. Try to water the grass evenly with this pointing across the yard.
B
BlaineBug
Clown World
View attachment 392983View attachment 392984
The fog on the left is from a GMT900 and the one on the right is from a K2 Tahoe. Both have the phillips screwdriver fitting so you can adjust them from behind. Looking at several 2015 Tahoe foglight videos on youtube this morning, there's plenty of room to get back there and adjust them with a #2 phillips.
Your suggestion worked, there are Philips screw heads for all of the 3 mounting studs. Only one of the 3, the inner most lower stud, has that plastic "adjustment" wheel so that's the only stud I adjusted, to move the light beam down. Very easy to do without even lifting the vehicle. I'll just have to test it on the road at night to see if I need to make any further adjustment.
B
BlaineBug
Clown World
My LED's don't have an issue. For the projector low beams, high beams, and fog lights, I have the light output set to the left and right at 3:00 and 9:00. Some people mistakenly orient the light emitting diodes straight up and down at 12:00 and 6:00 which isn't right for use with a parabolic reflector.
I have a pretty decent and crisp visible cutoff for all of these lights as well.
petethepug
Michael
SoCal
My apologies for sounding like I've grouped your handy work with every character here in SoCal that's turned their import sedan into the equivalent of a full-size truck with a 3" lift shining through the back window.
The aftermarket lamps are so out of whack here they may have actually been adjusted, but it didn't make a difference because of how they're installed. If you ever see or hear of a driver on a high-speed chase for throwing Velveeta cheese slices on cars with lights out of adjustment, it isn't me giving them the cheese touch.
B
BlaineBug
Clown World
About 3 weeks ago we were on the return leg of a 19 hour 1,150 mile road trip. Somewhere in Kentucky or southern Indiana I passed a Dodge Ram 2500 or 3500 hauling one of those ramp trailers - an independent car carrier. He had 2 or 3 super bright LED lightbars on. Just about every car and truck on the road coming in the opposite direction was flashing this r3t@rd.
I was only getting flashed when my fog lights were on, but I also had a little bit of squat action occuring in the rear due to having a load and a cargo basket hanging off of the rear end as well. I really wanted to use my fog lights all night long but couldn't. I was never flashed once due to the headlights alone.
petethepug
Michael
SoCal
Meh, no big deal. On longer trips like that just replace the normal pop up utility on your truck with something that’ll take care of bright lights. It’s a simple plug n play swap for one unit to another.
Change this roof accessory to ...
This roof accessory ...
Dafrog
