Fog light isn’t working
O
omarrrr239
can't tell if that is lit up or not, when the plastic wears off it will show up as that blonde/natural color plastic underneath.
you stated that you replaced the switch already, does not appear to be the case based on your photo.
per your initial post.....
"I need help in why my fog light isn’t turning on in my 02 Yukon. I replaced the fuse, the relay and the switch"
I got 2 switches from the junk before buying the new switch. Because I was hoping the original switch was bad so I got two from the junk yard before buying a new one and well even with the new one it didn’t work as well
as well? the problem is intermittent?, please clarify if the backlight is on behind the fog light switch without the button being depressed first. or if it does or does not light up when depressed. read carefully what I asked before answering, your answers are not very forthcoming.
Fless
Super Moderator
Elev 5,280
I think "as well" may mean they didn't work, either, also, etc. Confusing, yes.
Yes, assuming so but not getting a yes or no is just dragging it out....
like yes it lights up when I press the button
and no it does not light up before the button is pressed
or no it does not light up
keep it simple
NevaLaccin08
