Fog light replacement?
a4edwin
ny
Bought some fog lights from rock auto last year but they bounce around like bobble heads. Looking to replace them and was wondering if anybody knows what would a better brand to go with!? Thanks
Is it the way they're mounted? Or are the internals loose?
mizzouguy
Lake of the Ozarks, MO
I'm sure we are having the same issue, but on mine the plastic mounting bracket holding the light housing to the mounting point is weaker/not as stiff, so when you mount it with the two bolts, the bracket still flexes/bounces going down the road. I even tried using the old spring because it was stiffer and it does the same thing.
