Fog lights AND high beams
cardude2000
Gotta be a way to do this. Anyone have any luck cracking this?
Haven't seen it for the '15 up, but definitely for the NBS and NNBS.
C
cardude2000
adventurenali92
Big Bear Lake, ca
Thanks. I found this but it's a dead thread regarding a bcm module. Are there others?
Thanks.
Fogs with high beams programming...
https://r.tapatalk.com/shareLink?url=http://www.tahoeyukonforum.com/index.php?threads/Fogs-with-high-beams-programming....64137/&share_tid=64137&share_fid=17772&share_type=t
That wasn't the one I was thinking of. Its regarding a pretty easy mod if I recall in the underhood fuse panel. I'm still searching for it. I just saw it a couple of days ago.
benski
Why would you want to have fog and high beams operate at the same time? It seems as if when you're driving in fog, the whole point is to not have the light bounce off the fog and back into your eyes. High beams will just make this condition worse. If you are talking about driving lights, those are a different critter altogether.
I'm pretty sure he's not talking about driving in fog.
pdrahcir
