Fog lights
Chefmiked
Hey all
I replaced my oem fog bulbs and they kept burning out. First thing I did was change the housing for possible water getting in.
It seem to work ok.
I then replaced bulbs with a plug and play Led. Now one of them burned out with in a month on the other fog.
Any ideas what this could be ?
I am not aware of what bulb type the 2021's use for fog lights but sometimes you can fit a bulb in that is rated for higher wattage that may resolve your problem, like the t10 bulb for instance is VERY common across all vehicle makes, yet some t10 bulbs can take more watts than others. If you put in a low watt t10 as a marker light it will burn out in no time.
Welcome to the Forum from NH.
Pics, please.
Other folks will chime in, as well.
ggilpin
