For those with amp racks under the second row seats..
sschrader
I am in the process of building one. How did everyone mount the rack to the floor?? Looking for some ideas.
thanks!
NoPh33rRaCiNg
Kent, WA
I don't really have an amp "rack" per say, but I have my big RD D9 mounted under there on some little risers, so the amp isnt resting on those seat bars mounted on the floor. they are just small plastic 1'' tall cylinder risers with a hole in the middle for a screw to go through, have 2 of them stacked on each other
S
sschrader
Gotcha, I suppose it's heavy enough where it won't be moving to much. c
MASS-HOE'Z71
Mass
I had some "standoffs" in my tool chest at work so I just ended up using those to mount the amp. not so much to keep the amp from moving but to keep the underside a little cooler by moving about an inch above the carpet. They look like this except are a little bigger to support the weight and the screws that retain the amp just screw into the threaded female end
brassknucklemafia
phoenix
picture.php
[/IMG]
S
sschrader
^^ So is that just sitting there or is it mounted to something?
brassknucklemafia
phoenix
its actually mounted to the lower supports under the seat. going to change it when i add three more of same amp. three will fit end on end, but four wont. so i have to figure something else out.
S
sschrader
Alright thanks!
I have the MDF cut and set into place (would never know it's not mounted now) with the amps on it, need to route all the wires through the bottom and then make a trip to the fabric store and figure out what to cover it with.
fullyauto12
