For those with coolant leaks/dash message
BOSS
The People's A D M I N
Dallas
Are you guys replacing the gaskets or the entire fuel pump? How can you tell if the pump is out?
I put some black light sensitive die in my coolant and low and behold, I have a leak below the pump.
So I'm wondering do I chance it and just replace the gaskets, or do I buy a hi-flow water pump?
B
solored
canada
id buy the stock replacement pump... if your motor is all stock and not super crazy i wouldnt think there would be a need to run a high flow pump. Unless its cheaper then the stock pump...
But you have to ask your self this... well I am taking the pump off to change out the gasket.. so i guess since its all aprt should i do the pump? is it getting to close to bein needed to replace?
i would change it, its all out... and then you dont have to worry about a new pump for a while...
BOSS
BOSS
Dallas
Thanks for the input, anyone else who ran into this have any comments or experiences?
I tend to agree with solo, I think it's likely that the gaskets are worn, but might as well replace the pump itself...I don't know much about the actual pumps though, are they build to last forever or what?
B
Mac
NY
With all the mods, and money spent on your truck.
You shouldn't try to be on the CHEAP on something as vital as a water pump, Don't you thing?. :Nonono:
Anthony
2004 Tahoe LT (MA)
Westen MA
LOL, or he just dropped $5,000 on interior and wants to save $$$ now. :p
TnTahoe
TN
mine was doing the same thing a few months ago, so I just replaced the pump, i got it from rockauto $91 shipped
BOSS
BOSS
Dallas
:word: Thanks guys
B
Boomer73
Boom Boom
Crownsville, MD
I had this at 98K miles in my 2003 Sierra and at 55K miles in my 2005 Tahoe. Replaced the pump in both cases. No regrets.
-B
BOSS
BOSS
Dallas
-B
Cool preciatecha man, in typical BOSS fashion I'm gunna swap out the tstat, water pump, do my efan swap and install a tranny cooler with a fluid change....can't seem to do anything small these days
It's cooling time~!
B
Tahoewhat
Ballin' on a Budget
TX
Mine is leaking also. Cant figure out where. Some say its the Dexcool. ??? Been told that by a few people. But dont the gaskets and water pumps go out pretty common. 05 w/ 60k miles. Just wondering. Is that all you did boss was get some dye in there?
Darius
