Got a wash in. Actually washed it twice and it seems to have lifted the overspray from last weekend.
Maybe the 845 didn’t let it settle? IDK for sure, but for now it will suffice.
I did clay bar and polish the whole front end and gave it a coating of 845. Only the roof has the Rejex left on.
I found the grounding strap from my hood to my firewall and realized why I did not have it on.
The HD hood side of the bolt had snapped off and I put it my spare parts box.
So I whipped up some epoxy and let it set overnight. Voila, it turned out to be strong enough to tighten the nut.
I do not have the OEM light, but found another thread discussing the strap and lights that is kind of interesting.
Especially when looking at the years it does or doesn’t have the strap and whether or not there is or isn’t a light in there.
I have the bolt on the firewall, but my OEM hood did not come with a light.
And further differentials from the Silverado to the SUV side.
Here’s the thread.
https://www.gmtruckclub.com/forum/t...lverados-hood-uses-a-ground-strap-why.110717/
ACDelco GM Original Equipment Body Electrical Ground Strap 15179982
My driver side end cowl had 2 of the 3 clips break off, making the fitment not very tight. I had a spare set so I painted the spare up and installed it with 1.5 broken clips. Grrrr....
At least the Esky antenna delete side is still a solid 3 clips for the time being.
Found a spare fog light switch at the junkyard earlier this week. Well actually I only wanted the fog light push button. I found 2 but one broke the same way mine did. It is so thin, that it just pushes through.
I got mine almost apart to change it out but it was being stubborn and moving the circuit board and then the fog lights wouldn’t turn on, so I gave up on changing the switch out for now.
I took a piece of black electrical tape, cut it into A Perfect Circle to cover the hole and much like the NNBS A/C buttons it is now covered.
Interestingly enough my fog light LED is out but the rear wiper switch 3 LEDs work.
Stupid little things can win or fail right?
Fog light switch electrical tape vinyl overlay.
Grounding strap installed and driver’s side end cowl piece.
A picture from last weeks painting and cleaning underneath. Still needs some love, but looking better.
Spare fog light slide switch.
