Free travel mod Help!
08stockhoe
I want to do the travel mod to my tahoe but, I don't have a plasma cutter or a way to get one. Has anyone tried a saw-saw, cut off wheel, even a torch. Any suggestions guys are greatly appreciated.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
sawzall with metal cutting blade
Cut it off at the bottom below the frame rail
jayson
Reno
I did it my self with a saw zaw and an angle grinder. i had a cutting torch but end up being a bigger pain in the ass. I used the angle grinder with a cutting wheel to cut the bumpstop bracket just below the weld on the outside of the frame. (be careful no to cut into the frame!!) Then i cut the outside of the that bracket off so there is access to the back of that bracket from the fron(or outside of frame). i did this so i could come at a 20-30 degree angle and cut the back side with a saw zaw. it is extremely tight if you dont completely drop the rear axel out of the vehicle. the angle grainder is essentail if you dont want it to look hacked up. you will also need to get creative around the front drivers side as the gas tank is right there.
In that area i use the cutting wheel to cut small pieces off, then came back with a flap Disc. you could can make it almost perfect if you have some pneumatic grinders and cutters.
End result was pretty good. looks clean and as if nothing was there. took majority of the day and im not new to the fab scene. you wil also need to get the axle mount bump stop. with a 4" drop you will have contact over large bumps.
there is a Sticky on this topic if you search it that has some pictures. well worth it though.
08stockhoe
08stockhoe
I tried messing with it this past weekend, I was a lil intimidated by it. How did you cut by weld, did you eyeball it and guess that you weren't going to hit the frame. That's my only problem just by looking at it. And thanks for the input too.
jayson
Reno
yeah i know what you are saying. you want to cut a **** in the front of the bracket and wedge a prybar or screwdriver in there. cut your line 1/8"-1/4" below the weld. you will see the bracket strat to seperate from the frame as you have the pry bar wedged in between part of the frame and bracket. (yes i eye balled it) after that i cut the the whole face off the bracket so i could get access to the backside of the bracket with the saw zaw.(from the outside of the frame) this is how you are able to acheive the 20-30 angle. this also left very little clean up on the backside of the frame/bracket. And if your doing this in your driveway like i did, and your not completely removing your axle, you will see its a ***** to get to the backside of the frame with the cutting wheel with out breaking your back or catching your jeans on fire..... ask me how i know.. ha:flame:
you can try to just use the saw zaw and going with the contour of the frame but i wasnt ok with leaving part of the bracket on the outside of the frame...
Note: i tried this at first but started cutting through the frame becuse i couldnt see the exact contour. maybe i got a little overzealous though....
here is the link for the sticky:
http://www.tahoeyukonforum.com/forum/showthread.php?t=29844
100% worth the time and effort though.
08stockhoe
08stockhoe
The pictures make it look so simple. Did you the use a saw saw on the drivers side ( gas tank) seems kinda tight to have a blade an inch away from it.
jayson
Reno
you can until you get to the gas tank. then you have to get creative with the cutting wheel or pneumatic grinder/high speed. For refference, the passanger side to half the time to do...
davemitchell117
