From a 2/4 kit to a 3/5
crazycrew
Vacherie, LA
So, in the next month or so, we should be getting some 24s with 295/35/24 for the burb. . I currently have Tony's 2/4 kit with djm hardware. . What's required for me to go 3/5? Only want the one more inch, not 4/6. Will it be easier to just order a new kit? . Can I keep the autoride? Really like that feature.
Another question, if I do just order a whole new kit, will this one fit on my 04 tahoe? I know the lca's are different, but are they the same spindle and rear spring? .
Thanks
Sent from my SAMSUNG-SM-G935A using Tapatalk
LADenali
If you plan on keeping autoride, you might be able to change the front spring to a 1-2 drop spring from belltech and cut the rear spring (5305 I assume) to achieve the 5".
I have a 4/6 drop and am thinking the 3/5 may be a better solution.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
what year is your truck. I can set it all up
C
crazycrew
Vacherie, LA
It's a 2012. Just trying to figure out what all I need. . Still not 100% positive on doing it yet
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Can you do my strut mod. If not then will.need relocaters from me
C
crazycrew
Vacherie, LA
I'll have to look at the thread, but I don't see why not. If so, will I do strut mod and get the tbss Springs? And what are the relocators you speak of? Sorry for all the questions.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
the relocators are used with autoride so you dont have to machine the struts. They are adjustable from 1-2 inches.
so relocators
camber kit
rear trailing arm relocators
rear my custom springs
done
elliotte08
