From a 2-door connoisseru
Jay Gavin
New to the forum. Looked for a long time to find wheel/tire combo that would fill out the wheel well but not extend beyond my factory fender flares on my 95 Tahoe or require a lift or shaving. Ended up buying a set of 18X9 0MM offset bronze colored FN wheels. I used bore centric rings, cause they have 108 MM center bore vs. Chevy's 78.3 MM. Tires are Toyo Open Country ATs -- 275/65/r18. Very pleased with the results. Probably won't add center caps. Previous owner had torqued up the front a bit, so I just added 1-inch blocks in the back to level it out. No shaving necessary and no problems with sharp turns, reverse, turns on rougher terrain, etc. Looked a while, so thought I'd share.
Bigmac18
Ive always loved the older 2 doors. I drove a 1985 and a 1994 Bronco for a long time. Nice Truck
Jon72
