Front blower not working on 5
mjharless
Some junk got into the blower and made it vibrate. I took it out and cleaned it and now speed 5 does not work. All other speeds work and start immediately, but as soon as I turn it to 5 it goes off.
Any idea what I might have done when I took it out? I did not unplug the fan motor.
M
mjharless
Thanks for the suggestion - Solved it already though
Found that I had burnt up the 30a fuse for the blower. That circuit is apparently only used for high speed. Seems weird, but obviously I have no idea how these things work...
southboundchicken
Jacksonville fl.
If u still have issues with the fuse blowing consider replacing the fan relay those things are junk and fail all the time fortunately they arent too expensive anywhere from $25-$50
Jeremytahoe
