Front brakes locking up!!!!!
mossy oak
Y'all I'm so lost on this issue! So I hit the brakes pretty hard and they stick as a pair on the front. Tap them again and they "unstick". They're super soft most of the time but after they stick and I tap them to unstick them, the pedal is much more firm! I haven't really tried anything yet cause I know so little about the ststem. Proportional valve sticking? ABS module? Any clues? Any way to troubleshoot them? Please help
M
mossy oak
Btw, it's only when I really get down on the brakes that they stick. Otherwise they are really soft
M
mossy oak
Anybody? I've searched but came up with nothing of little help
afpj
First things first, general maintenance. Have you flushed the brake fluid? Check your pads and your disk rotors and grease the slide pins.
Danny3737
First thing I'd check would be the master cylinder.
SevenFortyOne
CT
I second this motion.
I Had similar problems in the past with my Dodge Dakota and doing exactly these things solved the problems. I've also had problems with dry/sticky caliper pins on multiple Toyotas and am now in the habit of checking them on all of my vehicles twice a year.
M
mossy oak
You guys are awesome. I work nights so I've been asleep all day and obviously couldn't reply sooner. Ill try fluid. And slide pins soon and report back
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Where are you located? Rust and corrosion build up in your caliper brackets can cause similar problem. Also frozen slide pins. I'd take your calipers apart and take a file clean where your brake pads sit. Also clean inside your slide pin bores. Apply some anti seize.
M
mossy oak
I live in Mississippi. The truck has lived here it's whole life. But I most certainly will try that. I'm fighting a few problems on it and have two little ines and a wife that's chronically ill so please y'all be patient with me. I also work nights so I may not be able to reply very timely but I'm trying and very thankful for y'all's responses
richardault
