Front bump stops
H8 PVMT
Got the bump stops. Mine were shot
My 00 Yukon 4x4
Front:15153958
Rear: 15039397
Front I got from a dealership because I had some time to replace them, 20 each. The rear they didn't have so I ordered them from GMpartsgiant.com for 15.00 each + shipping. Easy enough to replace, no bolts, they just pop in - I used a pry bar.
Hope this helps someone else.
Big Poppa Pump
Brunswick Maryland
My 00 Yukon 4x4
Front:15153958
Rear: 15039397
Will these numbers work for a 1999 Tahoe 4 wheel 5.7 liter?
H8 PVMT
If you go to GMpartsgiant.com and enter those numbers I think it'll tell you if it works for your 99.
crabbman
GYPSUM,COLORADO
Just ordered a set, has anyone replaced theirs yet? are they just pressed in? The center is hollow, do they unscrew? Thanks in advance for your reply.
I was told you pull them out,not sure what kind of tool,hands or real tools. to install you lather them up real good with soapy water and press it back into Control arm with your hands or real tools. that is what I was told. I will be doing this soon myself and I will probably give you a different story for that is what a D.I.Y. mechanic does.
pnwdan
Cunning linguist
Arlington, WA
It is as simple as that. Jack it up and swap them. Don't need tools or to remove the tires.
tinkersmithinc
