front bumpstop bracket
thehoe92
fo sho
The916
actually jerry it does mean something.. I think max was telling me something about the Z71 bump stops and how you will no longer bottom out any more they are actually called jounce stops
chistoso
Arizona
Interesting... It just rides so nice right now I would hate to jinx it by messing with it at all. I was actually PMing Max about doing away with the autoride and going with a set of bilsteins. This was when I had a crappy ride with the rubber removed so I decided to give it a whirl with the rubber installed and that's when everything changed. Probably a difference between Jounce and Bump Stops then..
ESCA-L8R
Huh? My day seemed ruined, and I contributed nothing by telling you that suspension systems are not designed to ride on the bump stops???
Bro, I wasn't even *talking* to you, just contributing some of the knowledge I've accumulated in 35 years of building cars and owning a hot rod and chopper shop.. Man, there's always one in every crowd. Ride on your bumpstops Amigo, it's your car, but you're still misinformed.
And really, I've never seen ANY car or truck suspension system designed to REST on the bumpstops. Do you understand that they're there to prevent the suspension from BOTTOMING OUT in cases of extreme travel???
Didnt mean to ruin your whole day like that, and i didnt know i had fancy pants coils or a fairly mainstream set of shocks i got on sale months ago. Also, where tahoes and yukons come out of the factory SITTING on the bumpstops, it seemed like a legitimate question to ask if there was anyone who had modified that portion of their suspension and what the outcome was or if there were any ill-effects of it.
As a side note i do have the drop spindles as well as keys up front
And now isnt useless to have 2 people post in the same thread and contribute nothing
SQNALI
Fort Collins, CO
ESCA-L8R is correct
tidbit of info.....
Bump stop is there to limit suspension travel, thus decreases "body roll" - prevents rollover tendency of the vehicle.
However, the bump stop may be set at a certain distance to limit travel of other front or rear end components, i.e. CV AXLES, SHOCKS
In other words, over-compression of the suspension may lead to excessive cv axle angles/stress/ accelerated wear/etc. May also lead to shock bottoming out (internally) and destroying the valving.
Just 2 cents
Maybe just 1 cent.....
denalianyone
NYBlackLade08
New York
You may not have seen it b4 but my truck and alot others from the factory were resting on the bump or jounce stops. I recently changed to the Z71 jounce stops and the ride quality is good.
MASS-HOE'Z71
MASS-HOE'Z71
Mass
My z71 sat on the bumpstop up front when i got it, as well as every other tahoe and yukon ive seen that was running a stock suspension. Its supposedly to make the ride a little stiffer and the torsion bar more aggressive. I could be wrong tho, im misinformed.
i still want to try it, just a little hesitent to start experimenting with a cutting wheel.
Tahoewhat
Ballin' on a Budget
TX
so from reading through this, Im not ready to cut anything yet, not that low and ride is fine for me, but i could put z71 front bumpstops in my non z71 and be alright and ride a little better lowered?
thehoe92
fo sho
The916
the z71 jounce stops are supposed to prevent you from bottoming out.. max told me (since he's so low) it raised him up like half an inch but you'll be fine mike
dan at the very least you should take the bump stop out and see how it rides I love the way mine rides without it and I'm still debating whether I should cut the bracket out
I mean if you think about it you won't want to go back to stock bump stops again so you might as well and if you start noticing rubbing on your tires put in the after market bump stops
Grocery Getter
A guy with a truck.
Phoenix, Az
I cut my brackets and run a low pro poly stop and while I like the way it rides my tires hit the top of the fender well on big dips so I may go to the 1.5'' bullet stops which would be about the same height as the original bracket by itself. You can get poly stops any size/shape you want.....button, rectangle, bullet....ect.......
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
there is no bind issues with cutting them out and going with es short bumpstops. Ive done many 5 inch drops in front ie spindels/djm 3 inch a arms since late 99 and not one customers truck has had the 4wd axles break or snap or anything like that.
Champ74
