Front diff leaking
mizzouguy
Lake of the Ozarks, MO
It may require what they call a redi-sleeve and seal. Its made for axles which have a groove worn into them from long time use. May look into that.
byrds6
byrds6
FL
If that's the case why not replace the axle spline. Wouldn't that take care of the groove? Granted the shaft is expensive. Little sucker is like 300 bucks
byrds6
byrds6
FL
2007. Has cv axle. That portion is fine though. The spline is a separate part that doesn't come with the rest of the axle
mizzouguy
Maybe crawl under it and see if there is excessive play up and down or front to back in that stub shaft that would indicate a bad bearing?
byrds6
byrds6
FL
Not sure if that would be a bad bearing or not. But you'd think they thought of that when looking at it to begin with.
byrds6
byrds6
FL
Yeah I know the feeling I'm tired of wasting money and time and the mechanic nit fixing it where I don't have to think about it again.
DogBoss
