front diff wires cut need pinout
FAMonmouth
my 4hi was blinking this morning so i started investigating. looked under truck and saw 4 wires cut clean and a empty plug on the front diff. looks like someone needed a new plug and swiped it from my truck.
i
I need the pinout for the actuator harness. what wire goes to which post until i can get a new harness
F
FAMonmouth
looks like a gray/black, black, black/white, brown. what wire goes to what pin?
95TwinTT
Minnesota
The generic diagrams from Haynes do not show the “pin outs”. What you could do is check out the wires with a meter to see what does what in what switch position and then take a +12 and ground clip lead and touch the pins in the actuator.
They obviously change polarity to reverse direction, so it will be two pins make it go one way and two pins make it move back. The fifth pin should be a indicator signal that is either going to ground or showing a + 12 when energized.
Or you could try to purchase that portion of a wiring harness from GM or visit a salvage yard and get the section you need.
Another possibility would be finding someone with a connection to one of the auto info services and get a detailed schematic from them. :)
95TwinTT
Minnesota
I just went out and checked my Tahoe. It's a 95 and it's manual for engaging the 4 wheel, but the plug and front actuator, looks the same.
Looking at your picture, if the upper left pin were pin #1 and the upper right, Pin #2, the middle, # 3 and lower left #4 and lower right #5,
I have Green on pin #1 Pin's 2 and 3 are not used and Black on pin #4 and Brown on pin #5.
From that I would guess that pins 2 and 3 are used for your indicator lights. Hope that helps..........
loulblades
Western PA
Here's the wiring I have.
The brown is power (when ignition is on)
Black and LT/Blue control actuator
Black/white is feedback to TCCM
ravingmadman
Chief Knuckle Buster
Greater Seattle
Wow. That's really fscked up. Let me know if you're still stuck. What year of truck? You need a signature. :)
707jimenez
