front differrential: trouble reinstalling wheel flange bolts
persistent
when i removed the bolts connecting the wheel flanges to the front differential, i recall thinking "wow, these are annoying to remove, i wonder how i'm supposed to torque them to spec on reinstall?". the time has arrived and i have spent 60ish minutes searching to no avail to find the trick to torquing these bolts to spec (58 ft-lbs) because the differential just rotates when i apply moderate amounts of torque.
i can easily torque the bolts to roughly hand tight with a socket wrench, but when i apply somewhere north of 30 ft-lbs with a torque wrench, the flange rotates and prevents me from torquing to spec. i would really appreciate it if someone would share the trick or technique to prevent the flange from rotating, so i can torque these bolts to spec.
the service manual gives no hints for how to do this properly.
P
persistent
i haven't tried this yet myself, but i believe this video shows the trick at approximately 8:00:
- use a pry bar to hold the flange in place and prevent rotation by inserting it between coils on the spring
i watched a few dozen videos before i found someone who actually documented this. literally every single other video i found would just cut from the wheel flange being disconnected to it being bolted on.
wjburken
Eastern Iowa
I have used a prybar that was long enough to lock into the studs on the wheel bearing and have the other end rest on the ground keeping it from rotating. Frees up both hands that way. That obviously required the wheel to be off. If the wheel is still on, simply holding the wheel to keep it from rotating with one hand has always given me enough resistance to get the proper torque.
B-train
Interesting, I've never once torqued those bolts. Usually a 3/8 impact with the correct amount of ugga-duggas does the trick. They are some high quality OEM materials, so I've never been worried.
But, to keep the axle from spinning, you could use a prybar across the wheel studs as a brake. Hold one, pull the torque wrench. Not the greatest, but if you had a helper, or a way to block it to something (floor maybe), then you'd be in business.
sportyjames
