Front electronic shocks
Rivelite
Chicago, IL
I agree with the above.
Most likely the rear shocks are torn and don't hold air anymore, which in turn probably over time burned your compressor out trying to fill them. I recall a conversation with a Cadillac service tech a while back when I replaced my rear shocks and compressor as I also have the Z55 RPO. She said while the full function on the rear shocks is definitely the best when the shocks and compressor are working together, the only real function of the compressor is to keep the truck level at the calibrated ride height under various loads. She went on to explain that it would be better to have new air shocks with a non functioning compressor than a new compressor with the original shocks as the compressor would not improve the drive-ability alone. The fronts are a bit different than the rears as they do electronically adjust for a stiffer or softer ride as necessary as the rears are "conventional" and just have the added air bag in them.
After their quote of about 2300 for the rears set up only, I went with Arnott and did the job myself for about 700 for all 4 corners and a few hours labor in the garage. I decided to keep the truck stock and went with the air shocks in the back instead of going with conventional and overriding the dash light for the ride height sensor.
Good Luck
Bigshawn
Mercersburg, PA
I have a 2001 yukon slt with autoride. It still has the stock shocks on it but i had to replace the compressor at about 220,000. You can unhook the airline going into each rear shock and pump them up with your home air compressor to see if they have leaks or will hold air. My old compressor i could hear everytime it would pump up but the new one is very quiet, i never hear it run at all.
Trailblazzin
Lancaster PA
Not trying to highjack this thread but, I’ve replaced rear shocks and front struts with A/C Delco’s, they were considerably more expensive but wanted to keep it like it was.
One of the fronts was making a squeak so I replaced both as was always told to replace in pairs.
The rears were showing some serious wear on the bladder but wasn’t leaking but looked like they could at any time. So I replaced both of those as well.
Now it doesn’t take bumps/potholes very well, still handles good on corners and at highway speeds. Seems really harsh, do I need to reset something to account for new shocks/struts? Could one of the sensors be bad? I have NO dash lights or codes on.
I’m the second owner and have all previous service records and one of the struts and compressor was replaced under warranty a long time ago but nothing else appears to ever have been done. 120k miles now.
What should I try? Any suggestions?
Big Mama
Virginia
Others will chime in but sounds like they may have overfilled. Does the rear look higher than normal?
You can try having the suspension controller reset to set the current ride at as it's "zero/base". This is a function for a dealer or someone with a TechII.
Trailblazzin
Lancaster PA
Sorry should have been more specific, the front seems to be the issue. Extremely stiff and harsh over bumps.
I might have to look into a tech2, I avoid the dealer like the plague. Is that normal to have to do a reset after a strut/shock replacement?
I can't say it's normal, but it's not farfetched and it'd be a good first step. The computer may just be still trying to firm up the old worn-out shocks. It doesn't know you have new ones. To see if it's the controller making the shock stiff, you can unplug the shocks and go for a short test drive. I recommend you do this on a street with no traffic and minimal turns. If your test road isn't immediately by your house, you can drive to it then unplug the sensors, reaching through the wheel wells. If it's much softer, then you can assume it's not defective shocks and it's likely just the computer needing a little help.
I don't know if the suspension controller is a separate computer altogether or if it's built into the PCM or BCM. If it's separate, you may be able to remove a fuse(s) to default it. Or disconnect the battery for a while.
If you do your own work on late model GMs, investing in a Tech2 might be worth it to you. I'd say there are at least five currently active members that have and regularly use one. James (@swathdiver) is one that could fill you in on the latest info and source. I spent about $200 on a really nice scan tool, but it's still just a one-way device. Had I known better, I absolutely would've spent an additional $100 and got a Tech2. But, the scanner I have is good for other, non-GM vehicles I may be servicing so it's not a total waste.
Trailblazzin
Lancaster PA
Ok, so should I unhook the sensors or the struts or both?
I’m going to look into a tech2 a little more seriously. I have to search around a little more and see where everyone is getting theirs.
Just unplug the electrical connectors on the top center of the struts. Don't do anything with the height sensors.
Roblusk
