front jounce bumpers
Rayyy
Northern California
Hey have you considered doing something for the rear?
Btw I found these control arm bumpers, which appear to be taller than the stock ones, but seems like they still wouldn’t come as close as your setup with the Energy Suspension mod.
I’ll probably install these with my Bilsteins and 2.5” front key lift, and see how close they are.
716F7028-0797-4C14-AD27-D4CFEE26DC02.png60280296-4921-424A-8729-387A2A09D123.png28CB1AB5-7166-40D4-B028-9FAAA79BDE2E.png
1xd5
Well after further research i found one thread on here yrs back and im gonna do the same.1 in button bump stop energy suspension-can add washers underneath if needed.I measured under truck not jacked up 1.25 or so space to control arm so it should work perfect or at least way better than what i have.Should be simple with a good drill bit which i have-will let anyone know that cares how it turns out.2nd pic is distance of my jounce to control arm alot of room there
How have these held up, if you did it again would you pick the same bump stop or go with something else? I'm doing bilstein 5100's with torsion key lift on my 06 Yukon Denali XL, and I'm pretty sure I'm going to have a gap so trying to figure out the best thing to do, so far it's looking like this may be the way to go.
Jongrreat
