Front & rear floor jack lift points
PG01
Up here to the right
Jack I bought 20yrs ago came with a second saddle.... can’t say ive ever used it but i have it.... as a matter of fct i just found it in my bsmt the other day....this is exactly the one i have.... although mine looks new. Jack is heavy tho.... hmmm maybe its tome for something new.....
wjburken
Eastern Iowa
Tozan
Overlander
Yavapai Arizona
these are pretty slick too if you have a use for them takes 3 seconds to jack a vehicle up
I wonder how stable those would be in the dirt? It might come in handy for a quick change while off road... I can just see this now get a flat pop that out up in seconds get out the air impact and tire is changed in pit stop fashion... My onboard air could handle this easy...
They specify their utility in dirt, mud, water, etc. Of course, they also list a handful of CYA's lol.
St. Louis
That's pulling down on an extension tongue, not lifting up on the receiver. Putting a jack under the reciever (2" square box opening) would be much the same as using a weight distributing hitch, which lifts the rear and puts more weight on the front axles.
I've used a floor jack under the reciever on my 2001 to lift the rear when rotating the tires after the front has jackstands under the control arms. Done it 2x a year for the past 10+ years with no problems.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
i thought our hitches only had a 1,000 lb tongue rating? wouldn't raising it by the hitch exceed it by a few thousand pounds?
I didn't see anything bend, so eff it.
FWIW, It didn't have the weight of the rear axle or spare on it. lol
I was lifting the body up to get more space to snake the exhaust pipe out, going over the axle.
Tozan
Overlander
Yavapai Arizona
I lifted mine with a farm jack on the hitch and my steel bumper flexed the frame enough to crack my rear tail light.. It moved about 1/2 inch... For the back end I just lift the differential and toss jack stands under there...
lbtahoe
