Front sits higher then back
95escahoe
So recently I threw on some new rims, now it looks like the front sits a lil higher maybe an inch or two, it rides fine, and the shocks are newer, is there anything else to check?
Sent from my HTC One X using Tapatalk
SunlitComet
OBS Jedi-Do Good
unknown at this time.
forgot if you had 4wd or not. if so you can un-crank the torsion bars a bit or use drop spindles or cut springs if 2wd. might have weak leaf springs in rear as well in which case they should be replaced. it should be noted that imply changing rims does not do that. the problem was an existing one which just now stands out a lot.
bowtiefreak
No Quarter
Near Philly
was the picture taken right after it came off a lift? suspension may settle a little if so
95escahoe
95escahoe
4wd, thanks for the input
Yup, and it might have been the angle of the pic
---------- Post added at 05:49 PM ---------- Previous post was at 05:48 PM ----------
Took a pic today, looks pretty level now
Roscoe2352
