I just picked up a 1999 Yukon for the sole purpose of plowing the 1-mile dirt lane I live on. The Yukon came with a 7.5’ Western plow with poly blade. The previous owner purchased the Yukon with the plow, and removed the plow for the 3 years that he used the Yukon as a daily driver. I put the plow back onto the Yukon yesterday and it completely crushed the front suspension, to the point that the lower plow frame was dragging the ground along the high spots on my lane. My guess is that the coil springs wore out during the time it was used without the plow attached. The Yukon shows signs of having had at least 2 different plows mounted to it over the years, so it's probably been rode pretty hard.
I am looking for a solution that is the best combination of low cost and ease of install. I can get heavy duty coil springs for around $100, but not sure how big of a job that will be when you take into consideration rusted bolts and such. Another option I found is the Timbren Front Suspension Enhancement System, which replaces the front bump stops with a hollow rubber “spring” that would act sort of like a ride-rite airbag on a leaf spring setup. The Timbren setup is around $250, but the install looks to be super-simple.
Any thoughts on these 2 possibilities, or is there something else that may warrant my attention? Please keep in mind the following:
- This vehicle will never see road use again. It will be used only on my lane and will most likely never be in excess of 20mph – so things like ride quality and body roll mean nothing in this application.
- I am fairly mechanically inclined and have the tools to do most jobs, but free time is pretty difficult to come by.
- This Yukon is definitely nearing the end of its life – my hope is to run it a few years (maybe 15 miles per year max), then sell it for scrap. As such, my only concern is keeping the plow at an acceptable height.
