Front Sway Bar Endlink Help After DJM Arms Installed
FarFromStock
California
What's going on fellas,
Been reading on here for a long time and never ended up signing up till just recently. Long time Tahoe owner finally getting around to lowering my Tahoe to give it a much improved stance.
I just recently installed the DJM upper and lower control arms on my 05 Tahoe and was wondering if you guys are using the stock OEM length front sway bar end links?
I measured my stock one and it is 8" long. Thought a 6 1/2 " would be a better fit. Did not know if any of you changed it out or not, and if you did what length you went with? Did not want to have any issues with tie rod ends hitting or any other complications.
Also, for those of you with the DJM control arm set up are you sitting on the joust stops in the front with the DJM lower arms or are they about 1/2" to 1" away from arm?
Thanks for the input. Stoked to be on the forum.
drackill1
