Front wheels seem to lock in 4 high only
Bigbody250
By any chance are your front tires worn considerably more than the back? That will cause it to pull to one side in 4x4 because you in essence reducing your ratio by smaller tires
---------- Post added at 04:03 PM ---------- Previous post was at 03:29 PM ----------
Sounds like similar issues....
http://www.letstalksnow.com/forums/showthread.php?t=27702
purple 'hoe
Green Bay, Wisconsin
If you had different gear ratios, the moment you put it in 4 wheel drive you'd hear a horrible sounds. If it's different gear ratios, the transfer case would be destroyed already. And possible both differentials.
Measure your tires. Check sizes. Check pressures. Might have different size tires which would cause issues similar to having different gear ratios
SunlitComet
OBS Jedi-Do Good
unknown at this time.
ignore the ratio in the transfer case it is just telling you how low the outputs can get but in 4wd the outputs are always identical. it is the front and rear diffys should match.
Meg_az19
